Old 03-22-2009, 11:33 AM   #10 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by ptr View Post
I have blocked the upper grille and it seems like it is a improvement of around 2mpg, still testing.
I want to change the side mirrors because i think they are making a big drag by the noise they make at around 70mph and upper. I found 2 types of aero mirrors but i need some opinion on which is better. Here are the stock side mirrors and the aero ones:
Your guess is as good as mine as to which is actually better... though just going by what I see, and (pretend to) know, the last picture is going to be the best, it has less advertised area (frontal area).
The second picture looks nice, but I'm afraid that's all... the big hole near the door just creates a "funnel" effect, which is good for making noise right next to your ear, as the outrushing air expands back into the air stream. That hole will probably penalize you if anything, so I'd stay away from mirrors (or anything) that create another point for flow to split into more than one pattern.
There's my 1/50 of a dollar... at least I think I'm right...
