Old 03-22-2009, 07:23 PM   #5 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
No, just check your grounds. The main fuel relay clicks uncontrollably when there is an intermittent ground circuit somewhere, usually the one that connects to the water neck housing (thermostat housing).
Check/clean/replace every ground you have, clean them all, then go do try to start it again. It's a pretty common problem, honestly.
