To make it even more perfect, your rear strut mounts are nearly identical to all the strut bearings in the Civic... so the Civic's rear coilover setup will probably come pretty close to bolting right into the back of your car. Might be worth looking into, If you happen to find a Civic with shocks and springs on it in the junkyard.
