Monitor leanburn Vx
To monitor leadburn in the Vx I installed the Autospeed Voltage Monitor kit which is 10 LEDs that indicate AFR by measuring the voltage of pin D14 on the ecu. I guess a single light would work almost as well but I found it easier for me to just get the kit . And yes the leanburn seems to work in all gears even accelerating ( engine warm ) if you do it veeerrry slowly. Not sure yet if it is better to accelerate briskly and cruise in leanburn or acelerate very slowly in leanburn. I plan to test this as I also have the MPGuino Kit which gives instant feedback
