Hey you guys. There has been much speculation that fitting a four banger into my Insight may provide some difficultly. You guys are probably right, and the only way that I will likely be able to come even close to succeeding with such a goal would be if I managed to secure a spot in my university's garage and had the help of a number of motivated engineers...
Getting my university's help is still a goal on hold due to spring break. Instead I've been spending this time by parting out the parts of the car I don't need--so if there is anyone here that would like an '01 IMA w/ 110k miles on it that was once suited to an automatic trans Honda Insight, then please let me know. Also if anyone needs a pair of sideview mirrors--cause you know how I feel about those--let me know as well.
Well my point is I found this image (attached below) of an Insight. It appears the owner managed to get two full liters v-tec in there. I'm sure some others have had some success as well with larger engines. I mean don't you guys remember the famous 9 second Insight.
Plus, guys don't forget that I don't even have the front clip for my Insight, so I may end up making a custom one to begin with. This could give me a little more room to play with.
I just wanted to give you guys some ideas to play with if you were thinking a bigger engine might be the way to go for this project.
