Old 03-24-2009, 11:43 AM   #637 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Battery volts: No problem. (well, not a huge problem, details of voltage sag and when to cut back, but not too hard)
Battery Current: No problem. Just add another hall effect current sensor,
or!!!!! You can use the rule:
I_battery = I_motor*PWM_duty.
This gives very good results, according to the EVTech list people. It can be computed inside the microcontroller! No hall effect sensor! Cheaper! ya!
And an input from a hall effect sensor that monitors a magnet that rotates on the motor post, in order to control RPM... In order to have cruise control mode! To protect from over-revving! To um, um, tell you when to shift up or down. It could make clutchless systems easier to find that nice good spot for shifting. I can't think of anything else.
Ya, Ben, with GPS of course (ben really likes GPS).
Ya, I like the data logger idea too. energy usage, money spent driving, time for full recharge, capacity left (taking into account peukert millisecond by millisecond!), um... I can't think of anything else. Oh! Set all the limits that you want from the console. Maybe set current limit, set change in current rate, um... and other stuff.
kits and boards
