Originally Posted by Piwoslaw
I think the vacuum in the engine accessories is greater than the vacuum behind the car, so it'd be better for cleaning up. I can just imagine having to clean all the hoses, nooks and crannies of the engine from the crumbs and dirt I clean up
That's the beauty of the design, it never needs cleaning. Or rather, it likely would never need to be cleaned because the motor would be destroyed by the first pebble or coin sucked in.
I suppose if somebody was crazy enough they could mount a vacuum cleaner bag inside a large diameter plastic pipe, and then fit both ends of that with tubes. One end for the "vacuum" part, and the other end to replace the entire air intake upstream of the air filter. Of course, the car is going to run like crap, but just think how much easier this would be than dragging the vacuum cleaner from the house to the garage!
