Old 03-25-2009, 03:30 PM   #10 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Adding a restrictor plate might allow you to use more throttle to achieve the same result, which technically ups the VE, right?
Couldn't you put the hole in the restrictor somewhere so that the air wouldn't even come in contact w/ the throttle plate if you were over like 50% of normal throttle?
