Chris D. -
It varies based on the weather and traffic, but with my HAI setup and grill block, it's almost always over 120 degrees F. Today on the freeway, with an outside average temp of 70+ degrees F, I was able to average over 130 degrees F. I think it was even higher, maybe 140+, but I forgot to watch it closely today,
If I can find some time this weekend I will take it out and take some pictures.
If you can make your JPEG just under 100K, then you can upload it without being rejected. I can change the JPEG compression using Paint Shop Pro, so I mess with the compression until my chosen image is just under 100K.
CarloSW2
