That is your opinion. A counter argument could be that a WAI increased the burn rate. Or if you increase the injection pressure, you get higher combustion temperature and more heat transfer, yet better BSFC. The point is, I think it helps, you think it doesn't, but none of us have put an engine on a dyno to test it appropriately.
