Old 03-27-2009, 12:46 PM   #157 (permalink)
eyesoreracing
Originally Posted by Deezler View Post
Whoo-hoo!
Congrats guys. Love the shots of the rabbit drifting sideways across the desert at the end.
One serious question: You filled up until the neck was full. Is there a vent-tube that runs along side the main filler neck though (to allow for expansion)? If you didn't "vent" the tank, you could still be off quite a bit.... hope that doesn't ruin your day.
Previous owner drilled a hole in the fuel cap. We picked up a screw off the ground and threaded it into that hole, finger tight, to keep fuel from dribbling down the fender. Still not air-tight, though.
By what mechanism would you expect the results to be off?
-Dave
