Old 03-27-2009, 01:47 PM   #63 (permalink)
captainslug
Misanthropologist
captainslug's Avatar
BORK! - '89 Volvo 240 DL Wagon
90 day: 21.27 mpg (US)
Originally Posted by MazdaMatt View Post
What is your hub motor and controller cost? What do you mean by "non throttle type"? Glad to see you're making progress
The controller cost $110 shipped. The motor cost $170 shipped.
The controller has two option for regen braking. You can set it so that the throttle control varies the regen strength when the brake is applied, or to have it just scale in strength from 0 to 100 percent off of the brake lever switch alone (with no control over the strength).
1200W controller? That seems kinda small to me. That isn't even 2 horsepower.
Of course it's small. The motor is only 1kw and won't go above 35mph with this wheel size.
This isn't a high-performance project. In fact is more like an electric bike with a slightly larger battery pack and no pedals.
I'll probably step up to a larger motor and higher capacity battery pack next year.
