Old 03-27-2009, 02:41 PM   #66 (permalink)
captainslug
Misanthropologist
captainslug's Avatar
BORK! - '89 Volvo 240 DL Wagon
90 day: 21.27 mpg (US)
New tires on the left.
Stripped the paint and dirt off of the front wheel spokes.
Cleaned the rims, which are now ready for paint.
Originally Posted by MazdaMatt View Post
From what you've learned, slug, would you say that an 80km/h bike is not a big stretch from what you've done? Or is that totally out of the scope of what you've learned with this project?
Frankly it's only a matter of your budget. All of the work involved is pretty much the same.
A $1,000 budget is very restrictive on the battery pack size you can manage (I only have a 1.2kwh pack on this right now). If you want 50mph/80kph you would need much more kwh in your pack, and a motor of 2kw or higher. That would then dictate a more expensive or DIY controller.
If you went with used/salvaged components like Ben did to make the Forkencycle, it's doable within the same kind of budget he had to work with ($2k or so).
What I'm making is a platform from which I can eventually go to a street-legal motorcycle. Configuration for that is yet to be determined as I don't like to pontificate too much on things I can't afford right now.
Markcycle over at the Endless-sphere forums is working with Crystalite to develop a motorcycle class hub motor with a hollow axle.
Endless-sphere.com • View topic - Motorcycle class Hub Motor
Ok, didn't know if you were planning on doing a lot of off roading with it or not.
I don't really expect to. Some of the routes I take around the neighborhood get muddy and the scooter I have now has abysmal wet traction. I went with dual sport tires so I can have good handling in gravel, mud, and snow.
