Old 03-28-2009, 01:17 AM   #160 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by Deezler View Post
Not sure how the rabbit tank is designed, just speculating here. On my car, when you fill to the brim, and then hit the vent tab on the side of the filler neck, the fuel in the neck disappears as the air in the vent tube is allowed to escape. You have to repeat this process severals times to really get the tank full. You can imagine that the amount of air trapped in the vent is highly variable...
There's the filler pipe down to the tank, with another line or two ventilation lines from the top of the tank to the large filler pipe, and one line from the ventilation line to an expansion tank up front. There's no vent tab so the amount per fill can probably vary quite a bit.
