Aeromodding Materials?
I want to make some screwon aeromods to my Echo. I already have grillblock, underbelly, rear skirts, and moon wheel covers. I want to clean up the front wheel arches with some screw on shaped clocks behing the tire and along the top. I also want to create some additional streamlining blocks to install in front of tires.
I think I read somewhere that spray foam insulation was compatible with fiberglass resin. That would be an ideal combination, if in fact it works. I know from experience that styrofoam isn't compatible with resin, infact melts when subjected to resin. Any other materials worthy of consideration?
Jim E.
