Old 03-28-2009, 05:21 PM   #4 (permalink)
gregted
Peddle Power !!!!!!!!!!!!
May have to fit a sail????????????
On a serious note
Is there a way to fit another gear for highway use or can I simply change the gearing to have lower top end, hence less revs but more range?
Does lower gearing mean less load on the motor hence more battery time?
I could live with lower speed if that meant longer range and no fuel...
I noticed most bikes are 48 volt. Is this optimal power versus weight?
I also like the idea of charging up from a bank of batteries that have been charged from a home solar panel.
If this is possible, do I need twice as many batteries with stored power to charge the batteries on the bike?
So many questions, so little time.
Greg....
" Aut viam invemiam aut faciam" I will either find a way or make one...
