Flat hubcaps / valve stem extensions?
Hi guys,
I've got myself a set of flat hubcaps but I am worried about losing access to the valve stems. I'm thinking that I can drill a hole in each hubcap and stick in a valve stem extender. Hopefully they won't stick out too much.
Does anyone know where I can get some for cheap? I think the straight ones would be the easiest to deal with. Also, I've done some looking online and some of them say, "Not recommended to be used with rubber valves." Seeing as how I know almost nothing about cars, how do I know if I have rubber valves?
