Old 03-29-2009, 03:42 AM   #3 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
A few people on teamswift have done the motorcycle carb conversion. It is pretty much only good for racing and top end power. If you are interested searching around on that site will give you some ideas on what is involved in doing it.
I don't think it would be easy to do but maybe drilling out the injector ports in the head and just adding 3 throttle bodies from a bike would work out good. With a setup like that you also would need to run a Megasquirt computer and a huge amount of custom tuning work. If you are really wanting to push the power and rpm limits on a 3 cyl engine it is probably a good setup to use. For economy it won't get you much if anything.
