Thread: Lights out EOC
Old 04-01-2009, 02:32 PM   #9 (permalink)
Drive Stick
Weight Reduction
Drive Stick's Avatar
Celica GTS - '02 Toyota Celica GT-S
90 day: 36.32 mpg (US)
Send a message via AIM to Drive Stick
Same here, but a lot of Subaru's lights only operate with the key as well.. leading me to believe you are turning your key too far. You only have to switch it to accessory to shut the engine off, not to off position.
either you're turning the key too far, or this is a new issue we will have to work around with wiring up an independent headlight switch.
