Old 04-03-2009, 10:43 AM   #14 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Christ View Post
Unused attic or upper crawlspace area can be used to partially collect rainwater in a container, then gravity feed it to the shower on the cold side.
That would be easy but... you really must be sure your ceiling and rafters can hold it. My friend has a 1 cu.meter (1000 liters) container for rainwater behind his house. It was standing on old bricks until the first rainstorm. The container filled pretty quickly, and 1 cubic meter of water weighs 1 (metric) ton. One brick crumbled, the over got driven into the ground.
Moral: Estimate how much weight your attic can take, both total and per unit of area. Having a ton water standing on an area of about one square meter might give you a bigger shower than you expected.
Also, there should be a drain out of the tank in the attic in case it gets full but the rain doesn't stop.
