Old 04-04-2009, 03:33 PM   #31 (permalink)
aerohead
MSPaint
Originally Posted by cfg83 View Post
aerohead -
Assuming for the moment that you have Windows XP, you can use MSPaint to make the image smaller (If I remember correctly, I don't think this will work for Windows 95 because MSPaint doesn't store JPEG files) :
Code:
Start
  -> Run...
    -> type "mspaint" in the "Open:" box
      -> click "OK"
File
  -> Open... (browse to file and double-click it)
  -> Stretch/Skew...
    -> change the percent in the "Horizontal" and "Vertical"
       to be something like 50%
File
  -> Save As...
    -> Save as DIFFERENT file name, or you will lose your
       original.  Make sure the "Save As Type" is set to
       JPEG for maximum compression.
Check if the file is below ~110,000 bytes. If yes, then you can upload it to this forum. If no, then you will have to repeat the process until the file is small enough.
CarloSW2
Thanks CarloSW2.The fella that owns the business here where I use the computer says when he scans a photo,it goes into Photoshop.I've been able to download photos from my camera and email them to friends,but don't know where to send them for ecomodder.com,as an attachment.Help?
