Originally Posted by Ritmusic2k
One of the biggest draws to Saabs is the fact that they're already a great platform for 'no compromises'. In fact, I'm already not too far away from my ultimate goals... In present configuration Carmen makes roughly 240hp, and I can get 40mpg out of her on the highway.
If you're close to your goal of 45mpg, then raise it 50mpg. Or even better, make your goal getting 45mpg not on the highway, but average.
Judging by your picture, Carmen has wide, low-profile tires on alloy wheels. Switching to slightly taller and narrower tires and pumping them to higher pressure (at least max psi minus 10%) would be a good start.
And when going to the store, take the bike
What matters is
where you're going, not
how fast.
