spliceing on a new short line is no big deal. i'd say you need a one factory end from any parts store.. better use a tube cutter. cut a end off. from any hardware or parts store get a tubing connecter of the right size. get a guy at the store to show you haw to put the ends and round parts together. don't mess up the cuts and cut too long. not too short. before all that you may want to put the front end of the car up. use a spray solvent to clean up and run it to see for sure where the leak us. making very sure it will not fall or drive of the blocks.
