Thread: Warm Air Intake
Old 04-07-2009, 10:35 PM   #9 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
I'm still considering something I mentioned awhile back about the Warm air intake thing: Here's what I'm thinking about:
Most cars these days have air filters which are contained in a box, usually a rectangle shape.
Heater cores are rectangle shaped.
Cable controlled water valves are easy to come by on older Japanese cars.
Install the heater core in the air stream of the air box, so that all air coming through the box has to pass through it, but leave the original cold air system in place.
Stick a thermal sensor in the intake tract, set to (insert good temp for your engine's intake temp).
Connect the output of the sensor to a small actuator which controls a water valve from a small Japanese car. (It doesn't have to be Japanese, but it helps. ).
Set it up so that the temp sensor will actuate the valve at your pre-requisite temperature, closing the water supply, which will allow the intake temp to cool slightly, until the valve opens again. Sure, it will open and close several times a minute, but it's a crude setup at best... would be great for testing.
For the hardcore, you could also just set it up on a hand control, and you could manually control it based on a gauge. Once the engine is warmed, there shouldn't be too much adjustment necessary, but it also makes it easy to drop the intake temp if you're experiencing problems going up hills and such.
true power on demand :P
