Old 04-10-2009, 09:37 AM   #31 (permalink)
Drive Stick
Weight Reduction
Drive Stick's Avatar
Celica GTS - '02 Toyota Celica GT-S
90 day: 36.32 mpg (US)
Send a message via AIM to Drive Stick
I have started working on my prototype part which will cover the section of tire which the stock bumper does not. This was supposed to be a final piece but I wasn't cutting straight so it doesn't fit how ever I will be making more cardboard models until I get the edge contour perfect.
Once I have the desired exact dimensions, I will cut the plastic almost identical to what you see here, give the inner edge a 45° angle so it can flush mount to the bumper, and attach it in the back with 2 mounting locations, at least. The leading edge will be sealed with a rubber gasket I have left over from truck flares, or some RTV if I can't find the gasket.
