Old 04-11-2009, 05:15 PM   #51 (permalink)
TestDrive
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
TestDrive,thanks for the input.I saw your post last session but store was about to close and couldn't respond.------- The computer that I use is in town and I pay by the hour for it's use.------- It runs Windows XP and the internet interface is through Mozilla Firefox.-------- The thing about the dashed lines,is that I'm not using any kind of word processing program for the text and there is no way to set tabs or do indents to signal a new paragraph.Pretty primitive!----------------- When Al Glidewell helps me send images with emails,he'll go through dozens of key strokes and dozens of windows before it's all done.He just leaves me behind in the dust.---------- Free time is none existent and I feel that if I juggle time to learn word processing and graphics,I'll never have time for the internet.---------- Once I get here to the copy center,it's kinda balls-to-the-wall until the clock runs out.Any help will be greatly appreciated.I have digital camera, and also scanning capability here,and so far have relied on Al do do all the image transfers.Thanks again,Phil.
Phil, first make sure you're logged on to the forum.
If you are, you User Name should appear on the right half of the page header.
Next, lets check your Edit Options
At the bottom of the Edit Options page you'll find -
If you're posting the occasional picture and/or attachment, you'll want/need to choose either Standard Editor or Enhanced Interface. I suggest you try the Enhanced Interface first as it is WYSIWYG (What you see, is what you get), while the Standard Editor shows you some of the underlying code (great if you're a computer geek, otherwise not so great).
Any of the three possible editor interfaces is still pretty primative - no tab stops or paragraph indents, but as an alternative to strings of dashes you might try pressing the enter key twice.
The first press forces the start of a new line.
The second press puts a blank line between paragraphs.
Given the situation with the pay by the hour copy center, it's probably not worth trying to rectify the photobucket situation other than you might ask Al Glidewell if Firefox, Flash and Java have all been updated to the latest versions. If any is not and he later updates it/them, you might give photobucket another try.
As a final note. If you start writing in the Quick Replay box at the bottom of the page and decide part way through that you wish you had all of the controls - like when you use the Quote button or start a new thread - just click the Go Advanced button. What you've already written will be carried along to the new page which includes the missing controls.
Hope this helps.
Name:	Ecomodder header.png
ID:	3213   Click image for larger version
Name:	Miscellaneous Options.png
