I'm playing with that right now. So far I have the radiator mounted flat in front of the engine just higher than the valve cover, drawing some air from the channel that has to be deflected around the engine anyway.
I've drawn the shape of the radiator and fan and have been moving it around a bit playing with options.
My other thought was to put it in the back and draw air thru it as the cars rearend terminates. Kinda like if you disguised a boatail with radiators under the end...
