Old 04-12-2009, 11:55 PM   #898 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
It depends a lot on the capacitors. You need a low Equivalent series resistance, so they don't dissipate too much heat with all the switching. People usually use lots of them because a bunch in parallel means the overall ESR is (in my case) 1/24*ESR_EACH.
You can try some large caps, but if they won't work, you'll know pretty quick. They'll get really hot. Try it! See what happens! It might be OK?
kits and boards
