TestDrive -
Originally Posted by TestDrive
Any reason to assume it's a scale drawing and not just an artists rendition?
That's a good question. Because it's all I have to work with, I am just trying to analyze it for what it is (in the hopes that someone will make one).
Hmmmmmm. If you had one of those weather "wind speed indicators" behind a dummy "grill box", you should be able to stick it out the window and see the grill block "close" at higher speeds.
CarloSW2
