autospeed did a quite comprehensive article about pressure measurement and even explained how to make a lo-fi pressure gauge with just a bottle and some tubing...
so provided you have a means of measuring the pressure you could do an A-B test where you test the pressure behind the grill with and without certain mods... if you make the airfoils angle adjustable you could even experiment with the optimal setup.
