^^A friend of mine turbocharged a older Civic that had the HF tranny in it. It was all he could find at the time. It actually ended up being really quick on the freeway because he could drop 2nd gear at 60mph and do one hard pull to almost 90.
It's been awhile since I played with mazda's but I know the Miata and 2nd Gen RX7 used the same rear end gears, and I think the transmission interchanged but you had to use the front bellhousing part from the Miata on the RX7 tranny.
Unchosen, I have autocad 2000 LT.
I'm going to scan them in here when I get them done, the basic shape and size of the car is done, but I have alot of components to measure and draw yet.
Our laser cutter can post process a program right off of a drawing so the more details I can get in there now the better. The parts will come pretty much ready to weld up and start bolting everything in without having to layout and drill a bunch more holes.
