Old 04-14-2009, 12:05 AM   #914 (permalink)
edown
EvEagle
You can't put batteries in a series string and tap parallel at the same time, even with diodes it is always a short.. If you could do this, then you could also charge your series string from a single 12V charger, which you can't. You CAN tap off each battery or pair but you can't connect the taps..
