Old 04-14-2009, 03:29 PM   #113 (permalink)
ev59rag
Maybe I missed it so kindly direct me to the correct post #.... but how are you going to synch the speed of the motor and the ICE itself... or you are just going to use one and then the other depending on the situation?
So if you are using EV then ICE is in neutral... then if youre going to shift to ICE then you just idle the EV... is this assumption correct?
