Originally Posted by Frank Lee
You have knowledge of straight through systems and how much the gains are?
Not with exhaust, but with fluid dynamics, which I compare liberally.
Basically, straighter pipe yields a higher available velocity, which creates a higher pressure differential across the valve, creating less potential for flow reversion. Less flow reversion means increased overall velocity, and the cycle is complimentary.
