Old 04-15-2009, 10:17 AM   #931 (permalink)
MazdaMatt
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
There's nothing special about the soldering in this project. From the components that I have seen, it is actually extremely basic. Through-hole soldering takes about 2 seconds per pin once you're on a roll and those mosfets need to be redesigned to mount correctly (through-hole).
Paul... possible reason for exploded leads - maybe the leads were not touching the copper at all. I would REALLY think about going through-hole with those leads. Even if you feel you must solder on top. Plated vias in a professionally made board would make a LOT more sense than surface soldering high power components.
