Old 02-15-2008, 01:35 AM   #13 (permalink)
Frank Lee
Originally Posted by diesel_john View Post
Exhaust systems on vehicles by their nature have a lot of vibration, so what the manufacturers do is they very carefully position the mounts at points called node lines. Based on the mass and stiffness of each component in the exhaust system and their resonant frequencies the designers use finite element modeling to predict where the best place is to put the mounts. then after testing the physical parts and tweeking the models for everything connected to the exhaust system they eventually agree on the size, weight, strength, type of rubber yah da yah da yah da. this is all happening at the same time the engine guys are saying they need this and they need that to change. Most of this is modeled now days, of course. Which translated, means: they can iterate on a solution faster than ever.
Long story short, it probably will rattle, it probably will cause a premature crack somewhere else, and it probably will change the torque curve of the engine. Will it matter once you have modds everywhere else on this car? No.
No kidding? The guy at the corner muffler shop doesn't look like a rocket scientist, and his systems are as good as factory. And, those rubber hangars all look pretty uniform, interchangeable, and universal to me.
