I can recommend that you get some OEM 13" wheels, and use those.
If you are near a junkyard, you might be able to find some easily. Some junkyards take wheels and tires off the cars.
IIRC - your bolt pattern is 4x114.3, for reference. If this is incorrect, there will be a Metroid here in 10 seconds to tell you otherwise. It's just how it works.
(Edited to show correct bolt pattern.)
