Old 04-15-2009, 09:55 PM   #35 (permalink)
winkosmosis
Originally Posted by DaveBirkenstock View Post
That's a common reaction, especially among fluid types who have learned over decades that laminar flow is the only way to increase aero efficiency (this explains the persistent interest in LFC despite serious operational deal-breakers). Their gut tells 'em that the added complexity and energy demands of the suction system can't possibly be more efficient than a streamlined body.
The net benefit can be shown by a modified version of the MPG calculator that MetroMPG put up in another thread. Even with the added power for the suction pump and for a design as poor as the one I posted earlier, the modified car consumes less energy at high speed.
A design that doesn't suffer the problems I pointed to will have a lower Cd figure and may require less suction power, too.
Skin friction drag is still there and is as real as ever. This drag can be offset by pressure thrust on the rear of the body at the cost of the suction power. The question becomes which setup is more efficient?
Does this help it feel less like snake-oil?
If not, where does it fall apart? I really am eager to learn where things break down.
-Dave B
Are you saying that the purpose of the design is to blow air into the low pressure area at the rear of the vehicle to increase pressure from the normal vacuum? That's fine with me.
But that isn't shown in any of the posts so far... the concept seems to rely on the shape of the tailcone
