Is This Dc Motor Ok For Chevy S10? I'm New To This
Hi,
I'm new to this, still learning.
Can someone tell me if this DC motor is good or not for a Chevy S10?
Here is all the info from the tag.
DC volts 36/48
KW 14.1
RPM 1325
Amps 330
GE# 5BT1366B162B
LENGTH: 17 inches
DIAMETER: 11.5 inches
WEIGHT: 200 lbs
It is from a 5,000 LB Forklift. I was concerned because of the low RPM but not sure how much that matters. thank you!
