Yeah shawn its on pages 3 and 4 between Frank and Christ. It's also on page 2 where Christ posts a picture and then we talk about it there for a while. Its also mentioned when Christ brings up his caravan.
And yes you can put a muffler and a cat on it. No reason you can't. Both are straight. I don't know how much you know about either but they are both just expansion chambers one with a thin membrane that reacts with unburnt fuel and the other that has baffles that reduce noise. Also the OP intent was not about these items as they may not be in the system at all. I actually had in mind using a new GDI engine lifted off a wrecked 09-10 with the smallest capacity. In which case as long as I can maintain an AFR of 24-30 I don't need any of those things because it produces less emissions than your engine with a cat.
