Is your car lowered? If it is, you can stop most of that wear by realigning your toe angle. (unless that's already been done.)
Camber isn't what wears your tires out when you lower your car... it's the misaligned toe angle that "drags" your tires up the road. It essentially scrubs the tread right off the side.
