Originally Posted by Big Dave
No modulation of front drive power? Should make for some interesting corners.
I think he means of the e motor, otherwise it sounds pretty suicidal on the mpg.
Full throttle would destroy mpg if that was your P&G technique, but the electric motor probably wouldn't generate enough extra force for it to be. . .crazy?
Could always cut it off once you clear the speed limit and then back on when you get where you want to be.
