Old 04-20-2009, 06:07 PM   #4 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
First see above edit I goofed up my first post
Originally Posted by Southcross View Post
"increasing"? you mean "more" Toe-in?
That is exactly what I meant
I would expect those things, but what if you decrease Toe to a neutral Zero degrees?
Depends on camber; on a car that runs heavy camber settings 0 toe is no big deal, on a car that runs near 0 camber the rear will be more "floaty"
Slight Toe-In I would suspect would have a benefit to turning/curve handling... as its pulling into itself on a curve vs pushing away.
That is how I've experienced it.
Toe-out I would also expect that from the rear end, it would seem that you have two tires pulling/pushing the car to the side as you drive, gawd forbid one suddenly lost traction.
Sorry; I've never tried that.
Edit: Can you even adjust toe on the rear of an 81 rabbit?
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
