Old 04-21-2009, 12:07 AM   #124 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
The other problem that makes it even harder is that whatever solution needs good bearings and seals to keep the oil or grease in. I am trying to make the car long term reliable without a huge amount of maintenance to keep it going.
So far my only working solution is to split the axle in half like I posted and move the motor over a few inches to give me enough room for 2 axles with a chassis mounted set of bearings.
Maybe this picture will make what I was talking about make sense
With just a few more inches of room that would work and solve all the stress and movement problems and just add the problem of future cv joint replacement headaches. The only problem I see with that setup is to make the 2 new joints that connect in the center come apart easily somehow so I can replace the sprocket when it wears out.
