Old 04-21-2009, 06:37 PM   #66 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Having been there and done that with diesels and automatics, all I can say is that if you GAVE me a diesel with an automatic, I'd trade it in. If you automatic does not say "Allison" on the side, a diesel will trash it. Even on the hyper-reliable W123 and W126 Benzes with their sloppy torque converters, you count on a new automatic every 50,000 miles or so.
I had a pickup with the wimpy 6.2 NA engine and it ate SEVEN automatics over the 300,000 miles I had it.
This project is fairly easy to start. Go on E-bay and find a C5 Corvette with a six-speed and a salvage title. Find a 6.5 engine and have Jasper overhaul it and drop it in. A 6.5 is about the same size as a small-block and the same weight as a 454. It is a drop-in. The hot-rod community is chock-full of vendors that will make adapter plates to match the 6.5 to a T-56.
Get a set of springs for a 'Vette with a 454.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
