You might also be interested in "The Soft head" which makes it's mention in "Talking heads" as well.
IIRC *it's been awhile, I need to refresh* "The Soft head" deals with the type of cam/head system that Comp was using in the 1980's on NASCAR engines, which was (again, IIRC) basically an atkinson-type cam with a slightly different profile, which allowed for insanely high static compression, (18:1 and more), without detonation, on the gas that they used back then, in a carb'd engine.
Something you probably won't like about Larry, as most don't, is his "that's old technology, let go of it" attitude. Anything that is a barrier is old technology. He finds ways to break it down.
