Old 04-22-2009, 05:04 PM   #53 (permalink)
consaka
Active Learning - '93 Chevy Suburban Silverado
90 day: 10.67 mpg (US)
Originally Posted by dcb View Post
Ah, missed that.
So the lead going to the injector, it looks like you will have to "break" it to get it through the hole. I would say wrap that injector lead around the sensor as many times as you can stand it, the more it looks like this, the stronger the magnetic signal to the hall sensor should be when current is flowing through the injector:
Or just wrap some appropriately thick magnet wire around the sensor and put it in series with the injector lead.
Aye, hooking the sensor lead up isnt my issue.. thats easy.. My problem is the supply. I dont want to burn the sensor up and it says 20mA max current to the sensor. the sensor has to have power to it before it will read the current in the injector wire. It is a three wire sensor similar to TPS sensors.
I know my battery is rated at over 600cold cranking amps. Im rusty on some of my electronic terms but it would seem to me that 600 amps exceeds the 20mA rating,,,,, just a little. To my way of thinking the supply should come on with the accessory link when you turn the key. I would really rather test this on the bench first though. Either way if my thinking is correct I need to limit the amps to the csla2cd first. not sure how. resister? fancy diode?
Last edited by consaka; 04-23-2009 at 11:03 AM.. Reason: Didn't notice the graphic in my quote. for quoting purposes it is totally unnecessary.
