Old 04-22-2009, 10:20 PM   #17 (permalink)
theunchosen
Apparently not so enormous. I knew it wasn't much taller(its shorter than I expected and than the older. . .tank looking mdels projected) but I thought it would have been wider than the Prius. I was pretty sure the Prius was narrower than the Del Sol, but I guess I was incorrect.
I should have known as the Prius is qualified as a mid-size(?)
The Volt in my mind was this http://image.automobilemag.com/f/gre...ept_design.jpg.
I may need to reconsider my original write-off as it would seem they have scaled back from the Camaro "green" counterpart.
