Originally Posted by Vekke
I also think you need a turbo diesel to do this more efficiently?
In my diesel I start to feel the turbo in the 2100-2400 rpm range, but I hardly ever get into that range (never when ecodriving). I doubt whether the turbo helps in the 1400-1800 rpm range?
This weekend I also cleaned up my intercooler which was pretty clogged. My IAT temperatures were rising in higher speeds so my max speed was 75mph. Now my IAT temperatures are 20 celsius lower than before and dont rise over 50 celsius. So you should clean your cooler now then to get the best gain of it  .
Hmm, maybe it's about time I unblocked it first? Then I'll see if it needs cleaning. If only I could find the time to make a temperature-controled grill block, then I wouldn't be worried about how much to (un)block depending on the weather.
What matters is
where you're going, not
how fast.
