His point is not to make the insight as FE as possible.
The people that mentioned he needed to clean up his post and get to the project would understand his project had they carefully read it.
His point is you don't need a hybrid to get good gas mileage. (as is proven by geos, but for the sake of argument geos are old and no one would drive one as representatives claim safety features and creature comforts in new cars make it impossible).
Fabio, your best bet is just to pull the components you don't want(hybrid) and leave everything else mostly stock. Maybe get some taller gears, but other than that its not going to be easier than that or cheaper for that matter.
Dropping in a new engine with diesel also won't prove his point. The insight's engine will be the easiest fit to the bay and there is already a drive train that fits it. Crank out the extra weight from the battery pack(if it only weighs 60 pounds the pack is pretty worthless as far as KWhr) and other hybrid components.
If you're going all out take the body panels off replace with carbon fiber, swap your seats for carbon fiber buckets with minimal padding and if it doesn't support weight on the interior rip it out. Dash, door panels, rear panels whatever has weight can go.
Drive it light and you can probably get better FE.
The other thing you will want to do is mount the radiator along the back of the car with a much larger area. It won't cool as well mounted flush against the back of the car but the increased area will allow for effective cooling. The heat being dumped into your wake slightly relieves the low pressure vacuum dragging behind your car by increasing the temperature so the fluid does not decelerate as much. Also dumping the heat at the very front increases the drag pressure on the nose of the car, all around not a good way of doing it if you can mount a larger radiator in a low pressure area.
